Home > In Car Electronics > Tow bar wiring |
rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150 |
Very easy, if you buy the kit It's basiclay plug and play.
Sun Dec 07 2014 6:02pm |
itsmeagain Member Since: 01 Nov 2012 Location: Birmingham Posts: 222 |
Any ideas how much the plug and play kit is?
Sun Dec 07 2014 6:44pm |
£120 from landrover I think |
Sun Dec 07 2014 7:04pm |
Gargy Member Since: 08 Jun 2014 Location: Gloucester Posts: 92 |
I paid around £130 from the Local dealer. It's around 2 hours work if you've never done it before.
Sun Dec 07 2014 7:19pm |
Ovey Member Since: 21 Jan 2015 Location: Portsmouth area Posts: 80 |
If you buy the plug and play set, do you need to have the tow software function activated on the car too? Or will switching the park sensors off manually be the only bugbear to put up with if you don't? Current: Range Rover Sport 3.0 TDV6 HSE in Stornoway Grey
Wed Jan 28 2015 1:15pm |
You don't need to have the software update for it to work.
Wed Jan 28 2015 5:55pm |
Ok Gargy, thanks for the info. Current: Range Rover Sport 3.0 TDV6 HSE in Stornoway Grey
Thu Jan 29 2015 1:23pm |
CDS Member Since: 21 Sep 2011 Location: Oldham Posts: 25 |
The software update stops the car raising and lowering automatically when Terrain Response is selected, useful to avoid the back end of the trailer being inadvertently grounded Over for a visit from disco3.co.uk |
Thu Jan 29 2015 1:40pm |
There is a difference between the 2009 and the 2010 model years.
Thu Jan 29 2015 2:02pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
You need to make sure the rear fogs are disabled when the trailer is plugged in. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Thu Jan 29 2015 3:09pm |
i'd not heard that, is it a legal requirement of manufacturers for that function? Bodsys Brake Bible
Thu Jan 29 2015 3:11pm |
The fog lamp cut out is sometimes undertaken by a simple metal strip in the tow socket, but not sockets have this.
Thu Jan 29 2015 3:48pm |
So if I have a september 2009 (MY10 facelift) does this fall into the category of 2009 or 2010/11 in terms of what I'll need to do regarding fitting/activation?
Thu Jan 29 2015 4:13pm |
It's a CCF edit IRRC Bodsy.....I always assumed it was to stop the reflection of the red lamps when towing something big like a caravan.... Over for a visit from disco3.co.uk |
Thu Jan 29 2015 4:49pm |
