![]() | Home > Faults & Fixes > Loss of power when pulling off when engine is cold. |
Williamsboy Member Since: 31 Dec 2014 Location: south wales Posts: 44 ![]() ![]() ![]() |
Just a quick update, I have today fitted the egr valve blanks and removed the pipes and butterfly flap. On start up all good and all was good on test drive.
Chris day Member Since: 31 Oct 2013 Location: Bexley kent Posts: 91 ![]() ![]() ![]() |
Well done and good luck |
Thanks Chris I will post again tomorrow if all is OK on my way to work.
Nav01 Member Since: 18 Jan 2013 Location: North London Posts: 99 ![]() ![]() |
how are you getting on Mike |
Hi Nav01 she is running like a dream. No issues today at all, should be a bit colder in the morning so will see how it goes then. Hopefully she will be fine, just need to get a service done now as I no longer believe that the garage did a service as they claim too. They may have fitted new brake pads front and rear ( with 22" 5 spoke alloys its hard to lie about something you can physically see) but I think they stopped short of a full service.
Here is the update the on loss of power i was experiencing when pulling away when cold, it's a bit late but here it is.
