![]() | Home > In Car Electronics > major electrical problems |
Did you have the CJB/fuse box out the car? Connectors on the rear of the module can be extremely fiddly to get back in correctly |
Cupra Member Since: 20 Oct 2012 Location: Kent Posts: 81 ![]() ![]() ![]() |
Yes had fuse box dropped took the green plug out the bottom, the thee on the front and that was all ? |
2 connectors on the back too |
Sounds like I'm taking it apart again, you wouldn't have a photo at all |
I don't have any to hand, sorry |
plugged those in and nothing |
Definitely? I have done it myself where they appear to be fitted correctly, but they are not... |
Both rear connectors control:
I think so, rear windows are working and locks work on the button inside but nothing else airbag light is on |
Personally, I would be double checking these connectors again |
will do, if not it scrap yard time |
All done, thank you for your advice, struggled to get the rear plugs in but now its working, strange thing my other problems such as shuddering have also stopped |
