![]() | Home > General > Noisy seat tdv8 hse |
Need to take it to a dealer, the rocking seat issue is well known and LR modified the seat base and mechanism. My car had creaking seat, was changed and became a rocking chair and was finally fitted with the update at about two years old. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Alfie Member Since: 21 Dec 2014 Location: Peterborough Posts: 141 ![]() ![]() ![]() |
Hi , do you think I might be able to get it sorted under a non landrover warranty at a main dealer ? Just wondering if this problem is classed as wear and tear or manufacturer fault ? Only way to find out I guess is to phone my nearest dealer tho I doubt any good will come of it 😩 |
As its a known issue, they can hardly dismiss it. Might be good to speak to customer relations once LR dealer has diagnosed issue |
Ok thanks simple1 worth a try |
