Home > General > FBH fault when linked to my Hawkeye shows transmition fault. |
Fritz Member Since: 24 Jan 2015 Location: NRW Remscheid Posts: 6 |
Hi I am new to this and have tried to find somthing regarding this problem with no luck on RRS 2006 10057 Kms.
Sat Jan 24 2015 1:15pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
Did you use the CAN-BUS adaptor when trying to communicate with the FBH? |
Sat Jan 24 2015 2:06pm |
No, I assume your refuring to the BA5080? Do I Need this then to gain access without getting all the errors being displayed? If so I will have to get one.
Sat Jan 24 2015 3:59pm |
Yes, you will.need the adaptor for the Hawkeye to switch between HS and MS CAN networks. Most of the systems are linked by HS CAN, but things such as FBH etc are all on the MS CAN network |
Sat Jan 24 2015 4:05pm |
Thanks a lot, as Land Rovers are getting more popular here we could do with companys like yours.
Sat Jan 24 2015 4:26pm |
It's easy when you know
Sat Jan 24 2015 9:00pm |
