Home > General (L494) > Timed Pre-Heater
dreynolds10
Timed Pre-Heater
Hi Folks
Has anyone retrofitted/coded the Timed Pre-Heat option onto the L494 yet? I know this can be done for the D3/D4 but wondered if it can be done for the L494.
Gap IIDTool + CCF + Antena and remote fob??? Just wondered if anyone had done it yet?
Post #449478 Fri Jan 23 2015 2:00pm
Bodsy
Site Sponsor
You can enable it, but you only get the fbh if you factory order the remote park option I'm afraid Big Cry
Have investigated thoroughly thanks to a couple of members here Thumbs Up Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #449482 Fri Jan 23 2015 3:15pm
dreynolds10
Hi Bodsy
Thanks for the reply. Dan at duckworths has a deal on the Webasto FBH at the moment, do you think its possible to retrofit this into a L494? I presume the loom plugs would be in place for a FBH but not sure whether the D3/D4 model would fit or whether the comms would work if its a different canbus?
I expect you have thought about all of these options and expect its a negative ????
Post #449493 Fri Jan 23 2015 4:58pm
Bodsy
Site Sponsor
No, different heater.
You also need to drop the fuel tank, , new wires, pipe work, fbh fuel pump, water pipe work, water pump, reciever, aeriel, plipper and enabling.
I don't think you'll get many brave souls retrofitting this just yet with the level of work required. Bodsys Brake Bible
See it HERE
Post #449506 Fri Jan 23 2015 6:42pm
FatJoe
United Kingdom 2006 Range Rover Sport TDV6 HST Java Black
Bodsy as you are a man in the know, a guy at work has the new one 3ltr diesel. Will this not have the FBH as standard? I'm not Fat. RRS TDV6 HST.
Post #449507 Fri Jan 23 2015 6:54pm
Bodsy
Site Sponsor
What do you mean by new....?
The rrs2 new new shape, no unless factory ordered (as above)
The 2010-2013 shape with 3.0 engine, yes, I can do that. Thumbs Up
Have a spare kit here I usually carry with me. Thumbs Up Bodsys Brake Bible
See it HERE
Post #449514 Fri Jan 23 2015 7:57pm
FatJoe
His is the new shape 2014. I just presumed they'd be standard on being as though I had one on my old version. The reason I ask is because I fitted mine yesturday from Bas amd he loved the idea Smile I'm not Fat. RRS TDV6 HST.
Post #449523 Fri Jan 23 2015 8:23pm
dreynolds10
Ah...ok...that makes sense Bodsy. I have not looked under the covers of the l494 yet and presumed that all of the pipe work would have been in place like the old ones.
It's a bit too new to start poking around to that extent....I'll go back to putting the body back on my D3 instead Laughing
Post #449526 Fri Jan 23 2015 8:41pm
