![]() | Home > Technical > Instrument Panel problem |
ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298 ![]() ![]() ![]() |
Hiya
stricko Member Since: 23 Oct 2014 Location: Bexhill on Sea Posts: 35 ![]() ![]() |
Hi
I have noticed today that the parking brake light still comes regardless of all the other items on the dashboard, if this is a clue as to what could be causing this.
moe696 Member Since: 09 Sep 2011 Location: Trondheim Posts: 3 ![]() ![]() ![]() |
Same problem on mine also. Did you find the reason for this problem?
Gajit Member Since: 02 Sep 2016 Location: Hautefort Posts: 4 ![]() ![]() ![]() |
Hi
Fish Member Since: 29 Jan 2014 Location: Glasgow Posts: 60 ![]() ![]() ![]() |
Hi, I had a nightmare with my dash. The first indicator something was wrong was that the HDC and special programs not available used to come up and reset when I switched off the ignition and the car went into sleep mode. This escalated to the door locks opening and closing and also the hazards would come on with no internal indication that they were on. The fault then started putting the car into limp mode with only slow speed available and the engine temp gauge would go full scale, plus all of the previous faults too |
Oh mines an 07 plate as well. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4460 ![]() ![]() ![]() |
With the GAP IID tool, you can now fit and program a 2nd hand IPC, and resync the odometer (upwards, not downwards) |
RRSCruiser Member Since: 02 Apr 2010 Location: West Sussex Posts: 41 ![]() ![]() |
Hi DM
attorneymlw Member Since: 31 Mar 2018 Location: Missouri Posts: 1 ![]() ![]() |
I was driving and noticed the cluster flickered for just a second. Over a few weeks it progressively got worse but it always came back on and worked until the next time. While taking the cluster out, I noticed the wiring harness behind the headlights was VERY loose (it basically unplugged itself as I removed the unit) but I moved on to unplug the cluster to see if that would somehow magically fix the issue. For a week straight there were no mishaps with the instrument cluster. Then it started again. Just like in the beginning, it was just for a split a second but I know this will get progressively worse. I have no proof ... but I think this is somehow related to the wiring harness behind the headlight switch, which as I said was really loose. My local RR dealership is not particularly honest .... so I'm trying to avoid a new cluster as I've read they MUST be reprogrammed for the car to even start again ... I think it's a wire issue but I don't think it's the wiring harness directly attached to the cluster. I really hope it's just this wire behind the headlights. Any thoughts? |
iannixon Member Since: 09 Oct 2016 Location: eastbourne Posts: 13 ![]() ![]() ![]() |
this is what happened to my 57 rrs...after lots of money spent investigating the dash was replaced and problem solved.. |
Hi Apologies for slow response, I am embroiled in yet another RRS fault, lumpy engine, no faults logged. Spent today locating two splits ion the air inlets and also a crushed high pressure vaccuum pipe and then using my GAP IID in live trace to monitor the EGR's I have seen No2 got from erratic oscillating behaviouyr when EGR1 is stable and flowwing. Using some cleaner in the fuel and in the inlets I now have the egr2 still oscillating slightly but now showing the same flowing movement as EGR 1. The car feels so strong and smooth, so not sure how long this has been degrading, I lost most of last year to severe health issues culminating in a massive heart attack and quadruple bypass, so that is why I went so quiet and didn't feed back what i found for my car. The fault I experienced with the car shutting down started last January after having a full gearbox flush, updated sump pan and filter and full fluids change as it was 10 years and 150K. If you read what happened in terms of the car, I spent a whole week tracing and checking so many connections and found things corroded, questionable contacts and voltage issues, this all happened upto the 25th Jan when i had a large stomach op and was laid off for nearly 4 months, in this time the car sat on the drive. Patrick at GAP was so helpful in working through what the IID was reporting In June I was well enough to go the next steps in fault finding, the difference now was the temperature, so I got the car faulting much more regular, which got me thinking. Long story short I then was able to get to a timed faulting process, ie the car was fine when initially started then would fail soon after. This would not reset until things cooled down, rinse and repeat. So this led me to rig up a crazy looking dash arrangement involving an office fan on an extension lead, a thermal image camera looking at the instrument cluster pcb and a stopwatch. I then could make the fault repeatable by using the cars heater ducts to warm up the instrument cluster and then by cooling down with the office fan, the car recovered and worked again. On the cluster PCB it was the components just to the rear of left large dial that went into a fault when it went above 35 deg C, once in fault if i cooled it below 34 deg C, bingo the fault cleared. This mant the cluster was basically unserviceable as it is all surface mount components which when i talked to the repair company that our warranty company was trying to use, they admitted they could not fix this. So the result was a new instrument cluster, which went in and sorted all issues, touch wood. This was all in June and was good timing as I had a herat attack on the 5th July and ended up with quadruple bypass, My wife was glad about the car being sorted as she spent a lot of time trawling to hospitals Flashback to January and your mentioning the power problem, there were two places where I experienced power issues, these were 1 the CPB in the left hand footwell, I spent a lot of time here as I could make the car fail when the fuseboard was flexed as I probed it, there are two bolts at the bottom that once loosened you can introduce movement and the car faulted. This went over 2 days and I found that a clip at the rear of the PCB, hidden from view may have been loose or nut pushed in properly. I cant say exactly but after pushing it home again I lost the faulting from this location 2 behind the cluster in the dash there is a loomed wiring that is running along the front of the dash and then splays off in felt wrap to the 21 pin connector that connects to the instruement cluster, thi smay be a red herring now thinking about the temperature timing issue I found but I had three occasions where the car faulted when i moved this T joint. So i stripped it back, but could not find any broken wires or crushed wires. I then went to teh connector and stripped it apart to check all the crimps. Nothing obvious, nothing apeared loose and i rebuilt it making sure everything was lined up and clipped. The fault mysteriously stopped happening when i moved this loom. I either had a total fluke of failures or again over the cars life things had relaexed/stretched and maybe i had improved things when i remade all the connectors clips and looms, but remember that did not fix it, until i found the cluster temperature issue as expalined. One thing I can say is, these are very complex beasts, beautiful when working and a joy to drive but when they glitch, far too complex, too many CPU's and electronics and its very hard to separate real faults from Comms faults from cascade faults I fear I have just done a ramble, its got much more detail I am sure and if you want more specifics I can look back at my notes for more clues, but each car seems to experience slight variances and so our experiences may help or may confuse. Let me know if you want more info Kind regards |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 ![]() ![]() ![]() |
I have traced the fault that causes the hazards flashing, doors locking and hevac, radio shutting down intermittently to the instrument cluster area. I have been driving about with the cluster hanging out behind the steering to try and figure out if it is actually the cluster or the loom connecting to it but haven't yet sussed this out yet. Anytime this problem happens if I wiggle the wires or move the cluster it usually resolves it.
Hi
