![]() | Home > Maintenance & Modifications > Total closure system ??? |
tonser Member Since: 17 Jan 2006 Location: Cobham, Surrey Posts: 244 ![]() ![]() ![]() |
Hi
You don't get this by default. Not sure if it can be programmed to do so. I don't think anyone has mentioned that it can be done on this site over the past 9 months..... have a word with your dealer and see if it can be configured (but don't get your hopes up).
Thanks Shmoogle - I'll give them a try. It would also be good if the access height was lowered and raised when the car was locked and unlocked.
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 ![]() ![]() |
Tonser, you can programme the access height into your key yourself. There is a third pushbutton (the LandRover one) on the key that can have a few different things programmed into it, access height being one of them. All covered in the owners manual. RRS TDV6 Bluetooth, VR, Roof ![]() |
Hi Lateral
Yes, this is a so-called safety feature. Apparently you have to warn people that the car is going to lower a bit... wouldn't want to get caught up in the air suspension now, would we? |
I wouldn't want to be a headlight if you're going to sitch on it! |
