Home > Maintenance & Modifications > egr blanking
maci234
egr blanking
maybe a daft question ,is there any need to use any gasket sealer when doing egr blanking thanks
Post #449114 Tue Jan 20 2015 5:32pm
Bodsy
Site Sponsor
shouldn't need one. as the blanks are flat or the expensive ones have an in built rubber seal. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #449115 Tue Jan 20 2015 5:35pm
maci234
the kit I got came with four o rings
Post #449117 Tue Jan 20 2015 5:44pm
Bodsy
Site Sponsor
You got the expensive kit then. Thumbs Up O-Rings will be fine. Bodsys Brake Bible
See it HERE
Post #449118 Tue Jan 20 2015 5:47pm
maci234
just to fit hopefully soon when weather improves, is it worth cleaning anything out if needed when doing this , it may be spotless anyway wont know till we start taking things apart
Post #449120 Tue Jan 20 2015 5:52pm
Disco_Mikey
Clean the MAP sensor while the throttle housing is out Thumbs Up
Post #449152 Tue Jan 20 2015 8:33pm
