![]() | Home > General > RRS break fade??? |
URX Member Since: 09 Feb 2009 Location: Edinburgh Posts: 194 ![]() ![]() |
Sounds like cheap pads on a 2.5 ton car....... |
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 ![]() ![]() |
And/or old fluid |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
There was a recall for a similar stiff brake pedal and poor brake performance.
Tha'ts not brake fade.... That's exactly the symptoms of oil in the brake booster.
jonesy#93 Member Since: 19 Jan 2015 Location: shropshire Posts: 9 ![]() ![]() |
Thanks for that I will check it myself just searched code po17 brings up the recall but lists tdv6 not v8. But think to be safe il book it in at a lr specialist in my area think roean are ment to be the boys round here cheers again |
Roean are pretty good. , but for this recall it would be LR only. Otherwise you'll have to pay for it. Bodsys Brake Bible
And tdv8, so uses the same vacuum mechanism |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
let me know what info you find as mine does it to |
It'll be the same problem Dave |
Just rang Kentdale land rover and they confirmed my had not been done and booked me in for this Friday to get recall done |
Ok cool il ring my local dealer tommorow not to sound stupid Dave but what did you say to them? Just inquire about the recall po17! Would be nice if it's just a hassle free fix! I take it that this fault may have just developed on mine as surely the previous owner would of sorted it! Cheers guys |
Cheers Bodsy your knowledge is awesome! |
Jonesy, drop me your vin number and I'll have a look. |
