![]() | Home > Faults & Fixes > HDC Fault, system unavaliable, normal ride height selected |
Does it coincide with a slight lurch/thud and momentary fluctuation of revs? Assuming not (as you didn't mention it) first things to check are voltage across the battery terminals first thing in the morning (look for at least 12.2 volts) before the first start and then after starting and running for a few minutes with lights and screen heater switched on (look for over 14 volts).
Mikey2089 Member Since: 19 Jan 2015 Location: Manchester Posts: 2 ![]() ![]() ![]() |
Just had 6 new injectors so the engine runs smooth as it was juddering and it was injectors that was the problem, this HDC fault was poppoing up before that job as well though...
Kensta Member Since: 17 Feb 2011 Location: North east Posts: 700 ![]() ![]() ![]() |
Had these warnings up on mine 3 separate times now , first was battery, 2nd time was Upper tailgate switch, 3rd time was brake pedal switch, hope that helps. Java black 2006 |
