Home > Technical > Windscreen wipers not covering all screen
myfirstrrs
I am hoping that someone can help me with a problem that started this (frosty) morning. Since then the drivers side wiper does not travel all the way to the right edge of the screen, it is stopping about 4" short which leaves a really annoying line of water. Could the wiper have slipped in the shaft if the blade was frown to the screen on start-up? The wipers were set on auto and were whizzing across as the car was warning up.
If so, how do I get it back to where it should be?
Any help will be greatly appreciated.
Post #448892 Sun Jan 18 2015 8:37pm
myfirstrrs
Any ideas please anyone?
Post #448967 Mon Jan 19 2015 1:31pm
Paddi
Try parking the wipers then go to the drivers side wiper arm and at the base is plastic cap. Prise off the cap and remove the nut below it. Pull the wiper arm off the spline and reposition it in the correct parked position. Push back firmly on to the spline and replace and tighten the nut. If this doesn't work or only temporarily fixes the problem then the spline may be stripped or the linkage damaged. To access the linkage and motor assembly you need only to remove the plenum chamber cover (the plastic panel spanning the base of the windscreen. 2008 MY Java Black TDV8 HSE
Post #448982 Mon Jan 19 2015 3:23pm
myfirstrrs
OK, I finally got to this today. I removed the cap and nut but despite pulling hard could not get it to pull off the spline. I felt that I was going to do some damage I pulled so hard but it wouldn't budge. Out of curiosity I then tried just turning the blade assembly in the direction that I wanted and it turned reasonably easily. With the blade assembly set in the right position I put the nut back on and tightened it up. Now, it will not turn so this makes it look like some sort of friction arrangement, not splines.
Does anyone have any experience of this?
Post #449725 Sun Jan 25 2015 1:37pm
PEACHY
I removed my wiper blade arms to replace a discoloured / faded plenum cover. At first the wiper arms seem as though they won't budge - a little releasing agent & a lot of force & the arms detach from the spline - fitting is then reversal but if you can twist - turn the arm in situ - it seems the spline may be worn. Definately a spline system Thumbs Up
Hope this helps. 16MY Estoril Blue SVR.............
Post #449727 Sun Jan 25 2015 2:06pm
myfirstrrs
It does, thanks PEACHY. Thumbs Up
Post #449730 Sun Jan 25 2015 2:44pm
Paddi
Sorry to hear you struggling with the arm. I use of these and the arm comes off nice and easily with no risk of damage:
http://www.amazon.co.uk/Sealey-VS807-Wiper...B000ROFC52 2008 MY Java Black TDV8 HSE
Post #449784 Sun Jan 25 2015 10:29pm
