Nmc880
Hi everyone, ime at my wits end, I have a water leak in my 2005 rrs in the passenger footwell, (under the carpet)I've read on here about the A pillar letting in water through the bottom hole and got that done a few months ago, and it seemed to stop, but after further investigation the water is not coming in from there, I opened the sunroof and checked all the drain holes and they are all draining as they should, the problem is is when I pour water down the sunroof Chanel at the front passenger side the water is draining under the car but some is managing to come in under the carpet in the passenger footwell, ime pretty sure the water is getting in once it drains from behind the passenger side vent as it is fine up to there, is there anywhere that the water could be getting in from the end of the rubber hose behind the passenger side vent and where it drains from there as it seems to run out the rubber hose behind the vent and on to the metal plate underneath then through a small hole in the bottom right corner and then drips down to the plastics cover at the bottom of the passenger wing ,if any of that makes sense, any help much appreciated as its driving me insane, many thanks
Thu Jan 15 2015 12:29pm |
