![]() | Home > General (L494) > anyone else finding that ... |
Andrew2706 Member Since: 05 May 2013 Location: Stowmarket Posts: 34 ![]() |
Thanks Malcolm. spoken to dealer. and he agrees there is some kind of shadow in the bottom right corner of the indash sat nav. he has not seen before but is "Investigating this with JLR". As for the front parking sensors I totally agree with you and have never had issues before with them on other vehicles. I now get in the habit of switching them on by touching the "P" when ever I start to leave my drive and also switch them on again when I come home at less than 10 mph. seems silly but me and brick walls have never mixed well !! |
mikef Member Since: 16 Sep 2013 Location: bucks Posts: 313 ![]() ![]() |
I would say that there are a lot of things slow to respond about the new RRS, apart from the infotainment system which is actually slower than my old L322 FFRR. The throttle response is dreadfully slow and I waste half my life waiting for the heated seats window to come up every morning |
ericr Member Since: 14 Jan 2015 Location: Kent Posts: 6 ![]() ![]() ![]() |
Thank goodness I have finally seen someone mentioning the acceleration delay. I've had my SDV6 HSE Dynamic for 3 months but noticed straight away that there was a delay between accelerator and the car moving off. I lost confidence in pulling out into gaps in traffic after having artics bearing down on me while I'm waiting for something to happen. I took the car back to the salesman for him to confirm that's how it should be and he said 'yep' and confirmed there were no new updates. I love the car in almost every other way (the satnav is bonkers and tries to get me lost) and can live with slow infotainment and door locks but I'll sell the car if that ridiculous and slightly dangerous accelerator lag cannot be rectified. Has anyone experienced it and had it corrected? I should add that occasionally the car takes off just as it should - so it can do it. |
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 ![]() ![]() ![]() |
We all have the 3.0 sdv6 lag... and it is appalling and dangerous but I guess we all get used to it and make allowances for it.
Thanks, Andman. Do you have any idea what causes it? It doesn't seem like turbo lag, more CPU lag. I wonder if the new uprated SDV6 with more power will have the problem fixed. You'd think that after a million miles of testing the bl**dy thing would work properly. The TDV6 can be chipped up for more power and better economy. I wonder if a non-JLR firm could tweak the CPU to solve this problem. Land Rover won't admit to the problem but I would bet the next model will have it sorted. Sadly, if I can't get this fixed the car will have to go. I didn't spend £73k to change my driving style to accommodate shortcomings. If only my S500 had grip in more than 2mm of snow...
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 ![]() ![]() ![]() |
The first gen Sport used to suffer from a lag sometimes - even the supercharged petrol. It was thought it was related to the gearbox as it tended to happen when coasting to a stop in traffic, stopping momentarily, and then trying to accelerate, and possibly was the gearbox telling the CPU to back off whilst it changed down into 1st gear. |
I've tried pulling away manually in sport mode but it's no better, and coasting downhill then giving it some accelerator it also still lags. Very occasionally, though, it takes off perfectly. My 14-year old Landcruiser doesn't have the problem. That's embarrassing.
Disco Member Since: 15 Nov 2013 Location: Telford Posts: 178 ![]() ![]() |
If you drive hard the adaptive learning assumes you are in a hurry and will give better response. Drive like miss daisey and all will be smooth and those in the back will not spill their drinks. If you then expect neck snapping pick up in the first 2 mm of throttle travel, then it will not as it has adapted to the easy style. In Sport Mode with Dynamic selected the response is almost too quick. The Sport is trying to be two cars. A Range Rover and a Sport. You could have one big switch for each. Instead we have some adaptive software that tries to guess which car you want it too be. |
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 ![]() ![]() |
I drive mine almost always in dynamic mode, and very often in Sport, and not aware of this lag. As Disco says the car has adaptive learning and will reflect on your driving conditions. I guess in normal non dynamic, non sport, the gearbox will change marginally slower and one of the turbos will just spool up that fraction slower.
It is very deceptive how fast these cars are.
Also, a bit anoraky...but I do tend to use engine braking quite a bit coming up to lights, either on the paddles or gearstick. It saves on the brakes and keeps the alloys cleaner for longer |
That's one of the many things I'm looking forward to with the SVR:
And probably a pronounced cackle from any OAPs in ther vicinity |
Dickie Member Since: 27 Mar 2013 Location: Hampshire Posts: 200 ![]() ![]() |
I recently swapped my SDV6 ATB for the Supercharged. I too assumed that I'd have similar issues with pulling away from stationary as put it down to the gearbox/CPU lag but I am afraid to say that the Supercharged simply doesn't suffer in the same way.
