Home > Technical > Headlamp adjustment location
micalee
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
I have carried out a search but am not clear on which Hexi Bolt to adjust for horizontal adjustment. My drivers side Xenon needs to move to the right a little.
Post #445280 Sun Dec 14 2014 12:10pm
You adjust both together by the same amount to adjust vertically, either one on its own to adjust horizontally. 2012 SDV6 - it's missing a couple of cylinders
Post #445293 Sun Dec 14 2014 3:23pm
micalee
I can adjust height no problem by turning the hex bolt however when i turn the other one to do left & right, nothing happens - just spins?
Post #445810 Fri Dec 19 2014 10:58am
D12TYJ
United Kingdom 2012 Range Rover Sport SDV6 HSE Buckingham Blue
Have you tried the inner had screws? There should be 2 on each light
Post #446039 Sun Dec 21 2014 8:57pm
micalee
I can see two hex screws, an outer and inner. The Inner ones do not do anything - I can adjust vertical just not horizontal
Post #446147 Mon Dec 22 2014 7:39pm
If only one works then it should do horizontal, not vertical. Sounds like something might be amiss with your headlight. Have you tried taking it out and checking it for damage (and checking it's correctly located in the vehicle)? 2012 SDV6 - it's missing a couple of cylinders
Post #446152 Mon Dec 22 2014 7:54pm
micalee
Lights still won't adjust horizontally on Adaptive Headlamps - the hex screw just turns?
Post #448319 Tue Jan 13 2015 12:47pm
Sounds like someone has broken it in the past. You might try taking it to a garage and asking them to have a look at it. Hopefully it's not broken because the headlamp units aren't cheap... 2012 SDV6 - it's missing a couple of cylinders
Post #448381 Tue Jan 13 2015 9:48pm
micalee
So, I took another look at this last night and something clicked whilst turning the hex bolt and it started to feel a bit more purposeful and low and behold, the light started moving!
Thanks for the advice and I can now adjust to my hearts content! Very Happy
Post #448409 Wed Jan 14 2015 10:21am
Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #448498 Wed Jan 14 2015 8:52pm
