Home > Technical > possible transfer box issue |
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 |
What happens exactly? What speeds or rev range does the noise occur? High speed? Is the sound still there when you drop it in to nuetral whilst travelling at the speed you can hear it at? |
Thu Jan 08 2015 7:14pm |
josh_rrs Member Since: 24 Apr 2014 Location: london Posts: 18 |
thank for the reply joe, it is all diffrent speeds it can accure when i have pulled up at a set of lights then pull away. havent tryed knocking it into nutural. |
Thu Jan 08 2015 7:16pm |
Welderman Member Since: 14 Jan 2013 Location: Chorley, Lancashire Posts: 146 |
I've just fixed my transfer box.
Thu Jan 08 2015 7:42pm |
no mate doest jump into nutural or turn off sum times is slightly clunky on gear changes. ive only realy got worried since this noise i have the tdv8 and it is louder than the engine when it happens. i have bought gearbox oil to do a flush to see if that helps but if its the transfur box im looking at big££ |
Thu Jan 08 2015 7:46pm |
Seriously. I found doing the work myself quite easy. Was the rear output bearing to the rear prop shaft. Never attemted one before. Took me approx 9 hours over a few nights.
Thu Jan 08 2015 10:20pm |
if it was a transfer box i was jist going to get a 2nd hand one and replace my self. what symptoms did you have with yours budy? |
Thu Jan 08 2015 10:22pm |
First of all sounded like wheel bearing whine, but after more driving it started to get louder.
Fri Jan 09 2015 8:33am |
Hey Joe (Welderman)
Fri Jan 09 2015 8:43am |
just about notice at slow speeds, but around 40 louder and louder as you move faster.
Fri Jan 09 2015 10:30am |
well today i had a boost pipe slipt to add to my troubles no biggy i found which one it is, back to the issue if i knock it into nutural when i hear the noise it stops. |
Fri Jan 09 2015 4:47pm |
I'd always start by draining the oil and re-filling. Check the oil to see if it's burnt or otherwise degraded. Bodsys Brake Bible
Fri Jan 09 2015 4:48pm |
i have diff oil gearbox and transfer box oil to change all of them im hopeing that will solve my issue if not where is best to get a recon trani box or a good second hand one ? |
Fri Jan 09 2015 4:55pm |
Josh I think Welder mans onto something. I've seen posts of people changing diffs etc and it never aolved the problem. If you change all oils and and it doesnt work I think Welder Mans bearing thing might be onto a winner as he mentions its just on light acceleration. I thought diffs made the noise on overrun too? Maybe wrong. |
Fri Jan 09 2015 5:38pm |
wile im underneth im going to remove the prop like welder man said and see how the bearings feel. its not a dif noise i dont think as it has only recently apeared and is defo gettin louder. thanks for ya help guys ill update when ive had a dig around |
Fri Jan 09 2015 5:42pm |
