Home > Technical > Parking sensor issue?
Andy d
My car recently started with a long beep from the rear when I turn ignition on and light flashing on pdc switch
Post #447576 Tue Jan 06 2015 6:25pm
Could be a failing sensor or wiring loom - probably water damaged.
I believe the wiring is tucked up in the rear bumper, could be worth checking for water ingress.
Also, check to make sure each sensor is 'clicking' when you put an ear to them whilst engaged, any that are not are the suspect ones. (I think that's the correct way around). Smile ON THE WAY: BMW F21 M140i
Post #447583 Tue Jan 06 2015 7:17pm
Nsp1
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Yeah, that's right.
Put your ear to each sensor (not while the cars moving tho Very Happy )
If it's clicking, it's working.
Post #447599 Tue Jan 06 2015 8:41pm
Nsp1
Any that don't click can be replaced by removing rear bumper (not as bad as it sounds) and removing the sensor.
They just unclip from the back. Half hour job and sensors are around £10 on eBay.
Post #447600 Tue Jan 06 2015 8:44pm
Bodsy
Site Sponsor
Some that still click, can give false readings, so looking at error codes and live values will help as well. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #447605 Tue Jan 06 2015 9:06pm
