Home > Maintenance & Modifications > Brembo Calipers refurb
seankenyon
United Kingdom 2005 Range Rover Sport TDV6 HSE Arctic Frost
Thought I'd share these pics of the refurb I did on these Brembo Calipers, filled the gouges with metal filler and sanded back to a smooth finish, scrubbed the remaining areas with white spirit and green scrubbing pads
I bought a painting kit from a website who supply various shades to manufactures which guaranteed the correct colour, the kit came with paint and a hardner which you mix, there is enough for 4 Calipers easily
Use the degrease included, add a coat of paint then wait 45mins before applying the 2nd coat the leave for 8hrs
Bought high temperature decals off eBay, so the materials in all cost about £50 to £60 plus the cost of the Calipers
I bought the pair with dust shields and brake hoses as this is the only difference from HSE spec apparently, other than different pads which were also included with a few mm of wear
Just need larger discs to get them fitted now
Hope this helps anyone planning to do the same
[URL=]
[/URL]
[URL=]
[/URL]
[URL=]
[/URL]
Post #447002 Thu Jan 01 2015 11:13am
Disco_Mikey
Post #447005 Thu Jan 01 2015 11:28am
Nice job. Thumbs Up
Post #447009 Thu Jan 01 2015 11:55am
seankenyon
Thanks Very Happy
Forgot to say - you literally paint it on with a paintbrush and it dries smooth with no brush lines
See link below, other colours are available
http://www.brake-caliper-painting.com/red-...erPaintKit
Post #447012 Thu Jan 01 2015 12:31pm
Disco_Mikey
Done mine with a tin of Hammerite Thumbs Up
Post #447016 Thu Jan 01 2015 12:43pm
Graz
Great job!! Where did you get the decals from?
Post #447071 Thu Jan 01 2015 8:36pm
seankenyon
My decals were off eBay, you need 100mm high temperature one's
Post #447079 Thu Jan 01 2015 9:19pm
URX
Scotland
Nice tidy ups Thumbs Up
Post #447088 Thu Jan 01 2015 10:54pm
ian-r
Disco mikey, are the brake discs EBC and is it on a supercharged??
Looking to change mine on the s/c soon and torn between drilled / grooved and standard. It stops well but I cant help feel some braided hoses / drilled groved discs may help? Yet when I research everyone recommends standard?
Post #447301 Sat Jan 03 2015 6:18pm
Disco_Mikey
Can't say I would recommend drilled.and grooved discs
These were 14 months old, approx 12k miles, and removed as they had warped
Ditched them and went for normal discs...
Post #447325 Sat Jan 03 2015 9:12pm
micalee
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Did mine while they were still attached
[URL=]
[/URL]
[URL=]
[/URL]
Post #448321 Tue Jan 13 2015 1:04pm
seankenyon
Got the brembo's fitted now, including new pagid discs, brermbo pads and larger dust shields / hoses
Also got the rears painted to match, well happy with the results:
[URL=]
[/URL]
[URL=]
[/URL]
[URL=]
[/URL]
[URL=]
[/URL]
[URL=]
[/URL]
Post #451710 Sat Feb 07 2015 5:32pm
shadrack
was just going to say can you use it while there still on the car, ive some massive tired looking amg cabipers on my ml63, got quotes to have them proffessionally done but while the price was around £250 i read bad press re using non oem seal kits to rebuild them and also the hassle of getting them all removed/ re fitted
Post #451730 Sat Feb 07 2015 7:01pm
daxmatt
just looking at the drilled and grooved discs,,are they worth it,need to change mine asap,and the price seems about the same
Post #545751 Sat Jan 13 2018 3:07pm
Cymruambyth
Wales
 Steve.
Post #545757 Sat Jan 13 2018 4:16pm
