Home > Wheels & Tyres > Stainless Steel Wheel Nuts
evomonkey
Found these at Wrington engineering , Good replacement for standard.
Post #447174 Fri Jan 02 2015 4:41pm
scarey
some good ones here as well,
http://www.ebay.co.uk/itm/Set-of-5-Range-R...rmvSB=true
Post #447191 Fri Jan 02 2015 6:57pm
Gargy
England 2009 Range Rover Sport TDV8 HSE Santorini Black
I work with stainless, so just be wary of using normal stainless for stressed area's.
I would of thought the normal wheel nuts are 8.8 hardness, or even 10.6................ Stainless steel ones are rarely hardened, and are usually marked A2 (304 grade) or A4 (316 grade).
Stainless also binds easily, and if it does you will end up with a nut that can neither be tightened or loosened.
I just hope they are rated for the job.
Good luck.
Post #447219 Fri Jan 02 2015 10:38pm
