![]() | Home > General > Tailgate Problem |
cubbyno9 Member Since: 22 Oct 2010 Location: Stepps Posts: 149 ![]() ![]() ![]() |
Could be a faulty upper tailgate switch. I had the same but the other way, kept popping open. If you can get into the tailgate switch you might find it full of water and what looks like loads of battery corrosion. I cleaned all mine out and it now works a treat again 2017 Range Rover Sport HSE |
rigpig100 Member Since: 30 Jul 2013 Location: angloa until the 18th !! Posts: 263 ![]() ![]() |
How do you get into it ? from the inside I guess |
I was lucky that as my tailgate was open I could pull the rubber cover off and get to the inside of it, the relay switch etc and get it cleaned. I had a right nightmare getting the rubber cover back on as I don't think I did it correct.
Cheers Bud, I guess I am lucky as mine is locked closed.
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 ![]() ![]() ![]() |
Ive got the same issue, button is faulty, but the 3rd button on my 2nd remote had been set by the previous owner to open it, so I know the mechanism works.
Alex C Member Since: 09 Jun 2013 Location: Southampton Posts: 146 ![]() ![]() |
New switch is about 20 pounds from Duckworth parts on here, easy to replace from the outside, use a flat screwdriver to prise the rubber cover and switch out. The switch has a prong each side to stop it coming out (bit like what you see on a side repeater when you take them out) just catch the edge of one and it will pop out. Takes 5 minutes.
Thanks Alex, that's a great help.
No worries Bob, good to be able to return some of the help others have given me on here |
I been out and looked, I can remove the lights, but not sure how to remove the switch.
dazzerboy Member Since: 18 Sep 2009 Location: staffordshire Posts: 212 ![]() ![]() ![]() |
switch just pulls out bit fiddly use a small screwdriver to prize it out if its stuck |
well the metal release has come away in my hand !! a tad corroded, new one on order.
Hi, unfortunately my upper tailgate has started playing up again, could someone tell me how to get the switch out. I took the rubber cover off the last time but couldn't manage to get the switch out however it did become loose but didn't manage to get out, thanks in advance. 2017 Range Rover Sport HSE |
I got my old one out by attacking it with a pair of cutters LOL |
Take the outer trim panel off following procedure in the video linked below and then removing the switch
