![]() | Home > Maintenance & Modifications > My DRL Installation 2010 RRS |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
here d-a-n:
d-a-n Member Since: 06 Apr 2014 Location: Dorset Posts: 13 ![]() ![]() ![]() |
Wow yours is a major install, good luck. One thing have you tested the lamps with the relay? my V10's wouldn't dim |
Mine dim but I had to use a third party module. Apologies that I didn't state this. I threw away the module that came with the drl's and replaced it with a different one, enabling the dim function with headlights/sidelights on. You can even attach it to the indicators so the drl's flash when the indicators flash (I chose to blank these cables though as I didn't want this function).
ian-r Member Since: 21 Jul 2014 Location: Nottingham Posts: 49 ![]() ![]() ![]() |
Best colour I have seen on a sport, would prefer a more OEM look to DRL but good job |
huininkk Member Since: 15 Dec 2014 Location: Ellemeet Posts: 19 ![]() ![]() ![]() |
Hi Tanloverluke,
http://www.rrsport.co.uk/forum/topic37731.html
Thanks for the link. I ordered and received the dimming relay, but now I am looking for the right DRL'S. The link supplied by D.A.N. is broken, so maybe somebody has a working link. I would prefer a DRL which looks the same as the original one. So with 4 forward facing LED's probably CREE.
This might help, be sure to ask if they dim as my V10 didn't.
if you read the thread that I linked to, you'll see that the drl's that I purchased tick all of your boxes, i.e. 4 led's, forward facing, CREE. Here is the direct link to the product that I purchased. I don't want you having a hernia ![]() http://www.ebay.co.uk/itm/High-Quality-DRL...20f2e36a1e Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project. DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights. TO DO: color code sills and pillars. |
Will keep you posted. (after the winterstorm over here) |
Cheaper here
if you can order from them, though apparently you have to be a wholesaler to order via their site.
