![]() | Home > Technical > TDV8 Fuel spill pipes "Popping off"... Help!!! |
RRS Daz Member Since: 23 Jan 2012 Location: Yorkshire Posts: 797 ![]() |
Yeah I've sort of had this when I replaced a spill rail o ring.
camel_landy Member Since: 05 Sep 2010 Location: Swansea Posts: 68 ![]() ![]() |
Cheers Daz,
Robbie Member Since: 12 Mar 2006 Location: Waiting for my old avatar to be allowed back... we miss her! Posts: 73 ![]() ![]() |
Sometimes it is caused by the return valve on the top of the fuel tank causing an over pressure on the return lines.
Is there a single line & valve to cover both sides or are there 2x valves/lines??
Just one set of lines to and from the tank. Once a side pops off it it tends to do it again and again. If everything looks secure and still pops off then the valve or return line is suspect.
Ta muchly...
Glad you got it sorted and enjoy your trip!
