Home > Technical > Locked car / open doors
TW3
United Kingdom 2006 Range Rover Sport Supercharged Buckingham Blue
Is there a way of leaving the doors open and fooling the Car that they are closed so the car can be locked?
In most cars I would press the door open sensor, but I can't find one on my RRS
Thanks
Post #446329 Wed Dec 24 2014 1:50pm
Bodsy
Site Sponsor
Alas not. I'm pretty sure You could with the rear tailgate, but not the doors. Having said that, I've not tried forcing the door latches closed.
Why do you want to do that? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #446351 Wed Dec 24 2014 7:55pm
TW3
Bodsy,
I have a 1 Amp drain on my battery and am trying to identify the cause. I've been following Robbie's guide and I want to start pulling fuses in the glove box fuse box but understand I need the car to be asleep, so locked.
Any guidance would be appreciated. Very Happy
Post #446361 Wed Dec 24 2014 9:51pm
Bodsy
Site Sponsor
If you leave the door open, the car will also go to sleep after a while as long as you don't close or open a door. So just keep the bonnet and passenger door open. Thumbs Up Bodsys Brake Bible
See it HERE
Post #446363 Wed Dec 24 2014 10:28pm
TW3
Bodsy,
Thanks very much, have a great Christmas day. Very Happy
Post #446366 Wed Dec 24 2014 10:48pm
Robbie
Location: Waiting for my old avatar to be allowed back... we miss her!
You can force the locks closed if you want, indeed that is what LR recommend in the workshop manual when looking for a current drain. It does simplify matters when testing at the CJB but if you are as forgetful as me tie a warning sign on the door so that you do not try to slam it shut against a closed lock.
Thumbs Up Land Rover - Turning Drivers into Mechanics Since 1948
How To - Battery & Quiescent Current Drain Testing
Free Fault Code Reading For Established Members:
Defender, FL2, D3, D4, Evoque, RRS & FFRR
Post #446395 Thu Dec 25 2014 3:08pm
