![]() | Home > General > Advice for prospective RRS purchaser - £28k budget |
Somerset Bumpkin Member Since: 12 Dec 2012 Location: Swindon Posts: 74 ![]() ![]() |
I went over budget and bought an early tdv6 facelift for high 20's so you should be able to get it for your money. I was originally looking at the pre facelift but so glad I spent more. They seem to be holding the money a bit better as well. |
Rich Member Since: 14 Nov 2014 Location: West Sussex Posts: 39 ![]() ![]() ![]() |
I've just bought a late 2009 facelift 2010 model from a main dealer. I ended up paying top money at around £30K but of all the ones I tested between 3 & 5 years old it was by far the best and felt right as soon as I drove it.
Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
Why would that be a problem? Its pretty routine that cars move around a small island within the trade. Mine came from Northern Ireland into the mainland trade before I snaffled it. The reason is they are worth more here on the mainland than in NI, and I am told, black unmolested ones are worth more in the north, and blinged-up ones that look like they ram raided a Halfords go south. I had cause to call up the original owner of mine; nothing fishy at all going on. It still breaks down just as often as one from a local main dealer would. ![]() OP: Buy spec, miles and history. Buying from an established member here would be a good way to go. But from anywhere, if you can pay pound notes, bid lower and hold out, or move on. Money talks. Also, paying one of the gurus here (if any are local to you) to turn out and look a car over may not be a bad investment if any will do that. Buying someone else's experience is always cheaper than learning the hard way yourself. |
I'm sure the vast majority that move around the country are OK but there were a couple of niggles that made me wonder.....
