Home > Technical > sport supercharged bandles like a cruise ship .(
needle
hi all , looking for some advice please ,recently bought a 05 sport supercharged and tbh it handles like a blooming sea going oil tanker just wallowing about on corners and very twitchy at speed(I had a full fat rr diesel before this and tbh the handling was 200 %than s thing .(,
So I put my Idd tool onto it and came up with a code in the vehicle dynamic control ,u0126-87 (00) lost communication with steering sensor,
Any ideas ? Tried to lower the whole car down to try make it handle at least like a 100ft boat (dropped my previous rr by20 mm and huge difference ) but it will only let me lower it 3mm? And still sitting high in my eyes.
any advice .thanks in advance
Post #445733 Thu Dec 18 2014 1:34pm
Paddi
Excuse my ignorance about SC's but does it have the 'Active Stabilisation System' i.e. with the active ant-roll bars?
If it does, then this is what the manual has to say about excessive roll:
Symptom:
Excessive Roll
Causes:
System bleed required
Stabilizer bar bushes
Stabilizer bar
drop-links
The DTC you are getting may not be relevant just because everyone tells me lost comms errors are often spurious. However the suggested action in the manual always seems to be 'check wiring' for these type of FTCs. If you clear the code does it always come back?
I would check the underside of the car to see if any of the drop-links have broken or there are any leaks from the anti-rolll bar actuators as a first step. And then second - have a look at the system reservoir to see if the fluid level is low. 2008 MY Java Black TDV8 HSE
Post #445737 Thu Dec 18 2014 2:25pm
needle
Hi , cleared the code so will try again tomorrow and have a proper look under the boat , not sure tbh just got what it says but this is serious unstable compared with full fat rr .(
Post #445738 Thu Dec 18 2014 2:28pm
Bodsy
Site Sponsor
upper Rear Wishbones. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #445741 Thu Dec 18 2014 2:48pm
Disco_Mikey
How many miles are on the car? There are a whole lot of bushes and ball joints that deteriorate and wear Thumbs Up
Post #445750 Thu Dec 18 2014 4:12pm
needle
70 k on it
Post #445775 Thu Dec 18 2014 7:52pm
