Home > Maintenance & Modifications > "A" Pillar clips
B9BS X
"A" Pillar clips
Hi guys Ive taken off my A pillars to colour code with a few other bits and the clips have broken off.
Does anyone know exact part number? the colour of the clips are white.
Ive had a look online but can only find yellow ones that look similar like the following;
http://www.ebay.co.uk/itm/LAND-ROVER-DISCO...446wt_1161
Will they do the trick or? Or will it be a trip down to the stealership??? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #445261 Sun Dec 14 2014 2:37am
Paddi
They look like the correct clips - the yellow ones supersede the white. Better still get the complete kit from Land Rover that includes the clips and was produced for a TSB to cure water leak problem caused by poorly sealed holes in the A pillar. Kit is part no. LDHB500400 does both sides for £9.00 2008 MY Java Black TDV8 HSE
Post #445281 Sun Dec 14 2014 12:30pm
B9BS X
Thanks Paddi, do you think the eBay ones will do the job? I'm also after the push in clips for the d pillar as 2 of them got damaged when taking off, do you know the part number for them? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #445298 Sun Dec 14 2014 4:59pm
Paddi
Probably but can't be 100% sure obviously. Try giving site sponsor Duckworth a call about both types of clip and Dan will likely give you a better price and send them out by post to you. Thumbs Up 2008 MY Java Black TDV8 HSE
Post #445311 Sun Dec 14 2014 7:24pm
B9BS X
Cheers mate il give them a call tomorrow Thumbs Up RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #445312 Sun Dec 14 2014 7:25pm
