Home > In Car Electronics > Sat nav wont access postcode or address screen |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 |
put your hand under the front passenger seat and un plug unit for a few minutes then re plug and see how you go |
Tue Dec 02 2014 9:17pm |
paul2415 Member Since: 10 Nov 2014 Location: essex Posts: 59 |
thanks for the advise,but tried that and still don't work ?? thanks. |
Sun Dec 07 2014 9:40pm |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 |
Probably a stupid suggestion but I presume you're stationary when you try it? Otherwise it won't work |
Sun Dec 07 2014 9:55pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1843 |
You are on GB as the country? 2023 P440e SE Dynamic on order -cancelled
Sun Dec 07 2014 10:09pm |
Yes I am stationary and in park,the previous destinations work if selected and will calculate the route if selected, just cant get to the postcode or address screens,when I press these buttons the green square around the button highlights and the dvd runs up but nothing happens ? |
Tue Dec 09 2014 12:41pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
Hard reset first |
Tue Dec 09 2014 12:54pm |
How would I go about that ? Thanks |
Thu Dec 11 2014 5:07pm |
Easy peasy. Unlock car and remove key, open bonnet and leave for at least 5 mins until everything powers down (car goes to sleep). Disconnect both positive and negative battery leads from the battery posts. Take a single jump lead and connect the positive battery lead to the negative battery lead for a few minutes. TAKE GREAT CARE NOT TO LET ANY PART OF THE JUMP LEAD OR THE BATTERY LEADS TOUCH THE BATTERY TERMINALS.
Fri Dec 12 2014 3:03pm |
