![]() | Home > General > Flashing red light under rev counter? |
Depending on what age your car is, mine was 07, one light is a tell-tail when alarm is set, the other a trigger code light which flashes a coded flash if alarm goes off. So two flashes for interior sensor, three for door pin switch, four for bonnet switch. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Chris day Member Since: 31 Oct 2013 Location: Bexley kent Posts: 91 ![]() ![]() ![]() |
Thank you for that! I couldn't find anything relating to the two lights" I wonder why it would come on after I had been out driving for sometime and only stopping for a few moments?
It is flashing three times so I take its a door light switch. Should it flash when I'm driving? |
Don't quote me on the codes, it was an example but no it shouldn't come on once you start the car. Sounds like you need to contact a grown up |
Don't know where I'm going to find one of those on here |
