Home > General > Issues since water ingress |
ian-r Member Since: 21 Jul 2014 Location: Nottingham Posts: 49 |
Sounds to me like water has got into the wiring loom or a computer. Realistically, you probably need to strip the passenger side out checking wiring connectors for obvious signs of corrosion. You could also try reading the fault codes which may narrow down there area your looking for.
Tue Dec 09 2014 7:29pm |
range27chris Member Since: 09 Dec 2014 Location: Manchester Posts: 3 |
It seemed ok before - these all seemed to come on with in a week or so of one another.
Tue Dec 09 2014 7:36pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Sounds like water has caused corrosion and as said its a case of looking at plugs and connections. It's not unusual that fault show up once things dry out. Hence why never buy a flood damaged vehicle. You will chase wiring faults til you get rid or rewire it. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Tue Dec 09 2014 8:42pm |
Isn't this a known problem with water ingress in the footwells? There is a CANBUS splice in that location that doesn't like getting wet. Not had the problem myself but if you search for splice issues there are a few useful posts. 2008 MY Java Black TDV8 HSE
Wed Dec 10 2014 9:31am |
Great will get looking thank you Paddi - see your in Heartfordshire, is there anyone you use or can recommend round there - am between Heartfordshire and Essex at the for the time being.
Wed Dec 10 2014 8:42pm |
Hi, I've not been able to find an auto electrical specialist that I could recommend. You'd need to find a place that really knows Land Rovers because the electrical system is so complex. For mechanical work I use Autoland in Houghton Regis and have no complaints but not very handy for your location. Expect you could find a specialist in Manchester and probably at lower rates than round here! Good luck. 2008 MY Java Black TDV8 HSE
Thu Dec 11 2014 10:47am |
