![]() | Home > General > Funny smell |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
Could it be the FBH? Not that I've noticed a smell from mine- but that's where it is. |
As already observed, check fuel burning heater and make sure there is nothing Stuck round it's exhaust. Found a cloth from mechanic when mine was services, stuffed up the side. Lucky I checked before firing it up. 2x TDV6. SE and HSE. Both returned to sender with issues👀
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
FBH can leave a horrible smell as mentioned. |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
I must be weird, I quite like the smell off the FBH, paraffin? Lovely!
Dave
crozzo Member Since: 25 Dec 2013 Location: Manchester Posts: 19 ![]() ![]() ![]() |
Sorry to sound dumb, but what is FBH |
Timf Member Since: 27 Feb 2010 Location: East Anglia Posts: 312 ![]() ![]() ![]() |
FBH is Fuel Burning Heater used by diesels to heat the coolant when the car is started and ambient temp is below circa 4 degrees. Smoke from front left of vehicle, & a smell in cabin is normal. Will go off once the car is warmed up. |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Mine also had this smell but after about 4 months it gradually disappeared, about the same time the neighbours cat did ! |
Top tip! 👍 Cheers Dave MY10 TDV6 SE (debadged ![]() Gone: a comprehensive list of imprezas and a Merc ML AMG |
