![]() | Home > Technical > Low Fuel pressure problem :-( please help |
Don't use Land Rover official dealerships unless you have to; they are extortionists. Find a good local independent specialist.
Astin Member Since: 05 Dec 2014 Location: Shropshire Posts: 3 ![]() ![]() ![]() |
Thanks for your reply could someone |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
it's under the car on mine, pretty much directly below drivers seat, same side as the fuel tank. you're gonna have to remove the gearbox undershield to get to it.
Thank you so much for your reply I'll have a look in the morning can anyone with a v8 confirm this thanks in advance Astin |
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 ![]() ![]() ![]() |
Search the forum for 'limited gears' a lot of problems point to alternator and battery. Maybe thats why it won't fire up very easy?
Kfa1950 Member Since: 26 Jan 2015 Location: Forster NSW 2428 Posts: 2 ![]() ![]() |
Had same problem, driving along then going into limp mode, suspension dropping down. checked fault codes, low fuel rail pressure. Changed fuel filter, fixed problem. Could have been a bad batch of diesel. We get |
