Home > Maintenance & Modifications > Battery and random faults |
Carlos3 Member Since: 14 Apr 2013 Location: Chester Posts: 40 |
Hi all
Thu Dec 04 2014 10:59am |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 |
good point Paddi. I would question who put the battery in, why they chose the spec they did? if it was under warranty then were they going cheap on you? the s3 is for smaller economy cars, from what i've read. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Thu Dec 04 2014 4:28pm |
Hugh Haddow Member Since: 03 Jul 2009 Location: Prestwick Posts: 202 |
The difference is usually the internal resistance of the battery. It varies between battery types and manufacturers.
Thu Dec 04 2014 4:37pm |
Hi
Fri Dec 05 2014 8:52pm |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 |
Hi, just to ask a thicko question, what's an AGM battery ?? |
Fri Dec 05 2014 9:31pm |
AGM is 'adsorbed glass mat'. Same chemistry as a convential lead acid type just a superior internal structure which confers performance benefits. I'm sure if you Google AGM battery there will be much better descriptions than I could provide. 2008 MY Java Black TDV8 HSE
Fri Dec 05 2014 10:37pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
The battery died on our TDV8 in March, got a gen replacement from main dealer, it was 850A, carn't remember the AH without looking but it was less than the old one. L/R had just changed there supplier to Exide so must think there a better performing battery, never had any trouble starting and it's not driven every day either. 2008 G4 RRSport TDV8 current
Sat Dec 06 2014 7:58am |
