Home > Technical > 35w vs 55w bulbs
micalee
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
35w vs 55w bulbs
Just bought some 35w D2S bulbs. I've just read that the RRS bulbs are 55w D2S - will my 35w bulbs be under powered and less bright?
Post #444222 Wed Dec 03 2014 8:57am
i would say yes, never done a car but my houses 55w replaced with 35w are noticeable and dimmer
not sure but will the power supply unit cope with 35w, or will it be overpowering them thinking they are 55w and lead to blowing early
Post #444225 Wed Dec 03 2014 9:26am
micalee
The ad said they were suitable for the car:
http://pages.ebay.com/link/?nav=item.view&...0677178673
35w Xenon HID Replacement Bulbs, Excellent Quality, 2 Years Warranty. UK SELLER
Post #444229 Wed Dec 03 2014 9:52am
i think the power ballast will be able to cope with the difference between 35w/55w
I suppose it will be down to you and the dark country road and whether you will be able to see or not
personally if i have 55w i wouldn't be downgrading to a lower wattage and having less light outfront Confused
Post #444230 Wed Dec 03 2014 10:06am
Ian.H
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
I fitted a 35w HID kit to my 1988 BMW E30 some years back (had fisheye lenses rather than reflectors). After one burner blew, I ordered a set of 55w. The difference was night and day (no pun intended) and was comparable to dipped vs main beam IMO.
Cheers..
Ian
Post #444233 Wed Dec 03 2014 10:25am
micalee
Great advice - thanks guys.
Ill order some different ones
Post #444234 Wed Dec 03 2014 10:34am
micalee
can anyone recommend some 55w 5000k D2S bulbs?
Post #444237 Wed Dec 03 2014 11:23am
try advance factors, site sponsors
Post #444248 Wed Dec 03 2014 2:22pm
I've recently put these in my RRS:
http://www.advancedfactors.co.uk/66240xnb-...3821-p.asp
They are plenty bright enough. 2012 SDV6 - it's missing a couple of cylinders
Post #444282 Wed Dec 03 2014 8:06pm
scarey
it should be 35w xenon bulbs only for your RRS, 55w halogen h7 are for the main beams....
Post #444335 Thu Dec 04 2014 12:19pm
micalee
My manual says Headlamps, low and high beam (xenon) 55w (D2S) Xenon
Page 271 manual
Post #444337 Thu Dec 04 2014 12:28pm
Advanced Factors
Site Sponsor
Misprint!
The standard D2S is always 35w LR part number XBI000030. You can get 55w from various internet sources but they would be modifications and most likely would need new ignitors, we would not sell them. The Halogen H7 for high beam is 55w. Paul Redding
+44 (0)23 8052 2776
paul@advancedfactors.co.uk
Post #444350 Thu Dec 04 2014 2:19pm
micalee
Spot on advice - glad i didnt blow my car up then! Thanks very much
Post #444351 Thu Dec 04 2014 2:20pm
Advanced Factors
Site Sponsor
Doubt you were at risk, if you bought 55w ones to run with your standard Ignitor (Ballast) pack I would expect them to be just poor rather than dangerous.
With Xenon bulbs there is no filament so it is all about igniting the gas inside and there is miles of difference in good ones and cheap ones, Stick with Osram, Phillips or other well known brands, they tend to live up to their claims in terms of performance. Paul Redding
+44 (0)23 8052 2776
Post #444354 Thu Dec 04 2014 2:37pm
micalee
Appreciate your advice. The bulbs I had got were these:
View item: http://pages.ebay.com/link/?nav=item.view&...0677178673
I havent used them yet but would appreciate your advice on them
Post #444356 Thu Dec 04 2014 2:43pm
