![]() | Home > Maintenance & Modifications > Door Mould Clips? |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9029 ![]() ![]() ![]() |
It uses two different clips which you can get from your local LR dealership. I have the same problem with mine and even after trying to replace the clips it still does it.
Harry HST Member Since: 09 Feb 2010 Location: Birmingham Posts: 296 ![]() ![]() ![]() |
Are we both on about the same trim...
I think so, yes. The sticky-out bits at the bottom that are normally textured and black but are usually colour coded by most on here. See edited previous post for the clip numbers. 2012 SDV6 - it's missing a couple of cylinders
There is a search function on this forum, try and use it
http://www.lrdirect.com/DYC101420-Trim-Cli...=DYC101420 In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
How easy is the door mould to remove?
I seem to remember it is clip and slide - hence the different clip fittings. 2012 SDV6 - it's missing a couple of cylinders
Sag Member Since: 07 Jul 2009 Location: Leicester Posts: 564 ![]() ![]() ![]() |
Harry, check the last post in this thread http://www.rrsport.co.uk/forum/topic30928.html LCFC. Receiver of threatening letters from Overfinch. |
