![]() | Home > Technical > Black Smoke. Turbo Pipe? Can I Put It Off? |
Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
My car has decided recently to pump out plumes of black smoke when floored or kicked down. It has always been a remarkably un-smokey car up to now. This has developed the last few weeks.
Intercooler hose is usual culprit. Easily replaced It's got a split in it or its delaminated. Bodsys Brake Bible
A new hose is less than £40, and takes around half an hour to fit |
Andyjay123 Member Since: 22 Aug 2014 Location: London Posts: 698 ![]() |
i thought if you had your car mapped it kicks out soot? 2006 RRS Supercharged 4.2 HST muthuaflecka! |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
I had this and it turned out to be a split in the actual intercooler which had to be replaced. Changed the hoses to silicones while it was out. I'd get it checked before you go mate as your options will be more limited once you're there. |
As it goes, I couldn't find anyone to look at it before we went, so I went anyway. Apart from smoke, all was well.
could still be linked with Intercooler, or could be EGR valves. First port of call on the intercooler hose and see how it goes from there. Bodsys Brake Bible
Thanks Bodsy. The pipe should be here in a day or two.
Worth getting it done as you will be getting worse fuel consumption too.
Mister B Member Since: 25 Apr 2014 Location: South West Posts: 179 ![]() ![]() ![]() |
I had the sloooooow pullaway then quick pick up a few weeks back and it was the Egr's, had them blanked and been fine since.
I read about those too, but I also read that both are unlikely to fail together and if the smoke is coming out of both exhausts as well, the pipe is the more likely culprit. Actually, looking at the photo of that pipe, and the price of them, if they go so frequently, I may consider having a batch knocked up to see if they sell. |
Interesting about smoke from both tailpipes. Didn't notice any on mine so i expect your right, even cheaper fix |
Yes, very simple to change, more difficult to get the friggin plastic clips off the lower plastic radiator guard thing in the wheel arch than it is to change the pipe itself. ![]() Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
Thanks again Bodsy. You are an asset to the site. |
