Home > Maintenance & Modifications > Not a good day of news today RRS Air compressor + EGR
dab130283
United Kingdom 2005 Range Rover Sport TDV6 HSE Adriatic Blue
Hi
Just been told I need a new air compressor to my RRS 05 plate has anyone tried the repair kit you can buy. Also been told I need to replace the EGR valves.
Post #443955 Sat Nov 29 2014 1:59pm
SRE
Spain
I assume it's a 2.7 Diesel, if so just blank the EGR's In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #443957 Sat Nov 29 2014 2:39pm
hard2beat2014
United Kingdom 2005 Range Rover Sport TDV6 HSE Chawton White
I got a full repair kit from landy air off ebay , fixed it a treat no more problems , only problem is removing the pump they get very corroded so do the pipes that go in the pump
Post #443967 Sat Nov 29 2014 5:52pm
dab130283
I have managed to remove the pump with only a slight problem of not being able to remove 1 air hose, I will have to have another look tomorrow. I have also ordered the repair kit since it was only £50 thought I would give it ago. How easy is it to blank the EGRs off.
Post #443989 Sun Nov 30 2014 12:07am
