![]() | Home > Faults & Fixes > New Crankshaft RRS 2008 2.7tdi |
End float? That's crank moving back and forth front to back. If the crank moves up and down by 2 mm it and sump would be on floor. Sounds like thrust bearing failure, usually associated with starting a car with clutch pressed so if an auto impossible. Am sure it's possible to refurbish the crank and for oversized bearings to be fitted but probably not cost affective. It does sound like oil supply failing so factor in new oil pump to price. 2x TDV6. SE and HSE. Both returned to sender with issues👀
If the car has a full main dealer service history, then it may be worth dropping Pete at Customer services a pm. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Nhlboy44 Member Since: 29 Nov 2014 Location: Essex Posts: 18 ![]() ![]() ![]() |
Thanks for the info
You will need at lease 5+ posts to be able to use the pm system.
The garage I went to said approx£5/7 K to replace engine? Seems drastic as might only be crank ? |
Just checked service book and has 3 main dealer stamps and 3 from Ongar garage which is a Land Rover garage but not a main dealer. |
http://www.ebay.co.uk/itm/Genuine-Land-Rov...1c49f69092 In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
£1450 |
