Home > Faults & Fixes > Torque converter advice please???
Chris day
Advice please! Im getting the dreaded cattle grid affect. Just wounderd if it is ok to change just the torque converter as i dont really need a £2500 bill just before xmas! the millage is 104000 and the gearbox all seem to change up and down lovely.
The only thing it is doing is up hill or when im hard on the gas is when it gets bumpy Sad
I had a mega flush done last year and it help but now its back!
Post #443792 Thu Nov 27 2014 12:41pm
Bodsy
Site Sponsor
do you notice the revs fluctuating when you get it? if they do, then its the TC. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #443796 Thu Nov 27 2014 1:25pm
Chris day
Thanks Bodsy
Yep the revs go up and down about 500 rpm
Do you think I might getaway with just changing the torque converter??
Post #443808 Thu Nov 27 2014 4:17pm
Bodsy
Site Sponsor
that sounds about right. Yes, TC and oil (of course) should sort it.
Sometimes though, it also masks a gearbox problem, but mostly it is the TC is the only thing that needs replacing. Thumbs Up Bodsys Brake Bible
See it HERE
Post #443810 Thu Nov 27 2014 4:24pm
Chris day
I do hope so' as it's £850 for just the torque converter and £2450 for gearbox and torque converter!
Thank you for you time Bodsy.
Post #443811 Thu Nov 27 2014 4:34pm
Chris day
Just a quick update. Got the RRS back today after having the torque converter replaced and all seems good. Nice and smooth and no more cattle grid for me. Let's hope the gear box last a little longer now!
Post #444858 Tue Dec 09 2014 11:18pm
alex3357
United Kingdom 2006 Range Rover Sport TDV6 HSE Fuji White
Hi Chris
Can you let me know where you got your torque convertor fitted ?
Is it still running well ?
Post #455745 Fri Mar 13 2015 1:17pm
Chris day
Hi Alex
Yes it's runner fine and let's hope it stays that way!
I had it done at JT automatics in Eirth Thumbs Up
I must say it made a big difference to the hole driving experience. Good luck
Post #455749 Fri Mar 13 2015 3:03pm
alex3357
Thanks Chris
Thats great to hear.
I have sent JT an email to see how long they would need my car for.
Its not too bad at the minute, but i need a new ecu which i have asked Bodsy to help me with. Just waiting on the part.
Thanks for the information, I will be glad to get the car running smooth again.
Post #456011 Mon Mar 16 2015 6:57am
Chris day
Good luck with all that! Highly recommend JT as they keep the car nice and clean inside and out!
They had mine about 4 days.
Post #456077 Mon Mar 16 2015 6:04pm
