Home > Maintenance & Modifications > Wear on inner edge of N/S rear tyre
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Good morning all, I have more than normal wear on the inner edge of the N/S rear tyre, is this caused by a worn suspension part or just in need of a proper 4x4 alignment?
Post #387142 Thu Jun 27 2013 7:00am
Graz
I had the same on mine and took it for a hunter 4 wheel alignment and the toe was out on both. So probably the same with yours.
Post #387227 Thu Jun 27 2013 9:03pm
I'd definitely get the alignment checked, as Graz says at a decent place with a Hunter system Thumbs Up
Search here for your nearest Thumbs Up www.alignmycar.co.uk ON THE WAY: BMW F21 M140i
Post #387235 Thu Jun 27 2013 10:58pm
1JBS
Many thanks for the responses, forgot to say that it just flew through it's MOT so probably is alignment... Thumbs Up
Post #387247 Fri Jun 28 2013 7:38am
darrenmcneill
England 2006 Range Rover Sport TDV6 HSE Tonga Green
Ive found that both my front tyres have wear on the inside. Ive found a local garage that have the hunter system, and have got a price of £50 for all four wheels.
Anyway, obviously there is a problem, would I be able to feel anything? Its just that I can feel vibration through the steering wheel at lowish speeds, and at 50 mph the wheel vibrates (You can physically see it). Just hoping the alignment will solve the irritating vibration? 2006 HSE for Sale - £7,499 (Manchester)
http://www.rrsport.co.uk/forum/topic46383.html
Post #443554 Mon Nov 24 2014 8:48pm
1JBS
Alignment wouldn't normally sort out a wobble / vibration this is usually down to individual wheel balancing. Thumbs Up
Post #443588 Tue Nov 25 2014 9:22am
