![]() | Home > General (L494) > Aircon fan always blowing |
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 ![]() ![]() |
In the climate settings you can set the default auto fan speed from min to max. So it can blow either quietly on min setting or on max settings it blows with a bit more gusto on auto. I think there's a medium setting in between as well. |
Nigel Tracey Member Since: 25 May 2014 Location: Lausanne Posts: 44 ![]() ![]() |
That'll do it.
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Always run the AC on, adjust the temperature. Don't be tempted to run with AC off. If you do, the system will eventually smell like a gents dunny! Gone - 2008 Stornoway Grey RRS 2.7 TDV6
OK found the setting, easy enough and set it to low, this has solved it.
