Home > Faults & Fixes > Suspension clunck every now and then
ccmpaul
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
Hi,any thought on my knock! I replaced the lower wishbones but I still have the same knock, the car rides without noise and can go up speed bumps without noise, but if the wheels go down into a pot hole or man hole lid the front end makes a cluck, I've had it back to garage that replaced the wishbones but they said there no play on any joints that would make this sound, could it be the mass damper, will these be fitted to my 05 supercharger ? Paul
Post #442641 Sat Nov 15 2014 11:48am
Anti Roll Bar bushes perhaps...or the Anti Roll Bar drop links. 2012 SDV6 - it's missing a couple of cylinders
Post #442670 Sat Nov 15 2014 5:48pm
PAS
England 2008 Range Rover Sport TDV8 HSE Santorini Black
hi paul,i've done my wishbones and ARB with new brackets ,mine made very similar noises after doing this.this afternoon between showers i fitted mass dampers and it has cut the noise down so much,can't quite believe it.p
Post #442675 Sat Nov 15 2014 7:05pm
ccmpaul
Where can I get the mass dampers?
Post #442682 Sat Nov 15 2014 9:43pm
flack
It will be your lower steering U/j that is worn, I had this on a few now, its only noticeable after the arms have been changed. Not a big job, parts around £90.00
Flack Thumbs Up
Post #442704 Sun Nov 16 2014 9:19am
ccmpaul
hi Flack, do you mean U/J as on the bottom of the steering column or track rod end type joint?
Post #442715 Sun Nov 16 2014 11:46am
PAS
mass dampers from main dealer ,£70 ish .hi flack ,I guess this mean I've just hidden the noise by putting the damper's on.p
Post #442725 Sun Nov 16 2014 3:05pm
