![]() | Home > Faults & Fixes > Suspension problem after my rr sport has been into garage |
Have seen it said that jacking up can sometimes upset a height sensor. They are quite crude sliding potentiometer design and suffer from dirt/corrosion that can be disturbed by jacking up. Luckily they are not expensive and easy to fit. Your 4x4 screen should show a height sensor fault.
andi1 Member Since: 06 Sep 2007 Location: UK Posts: 21 ![]() |
Hi how do i check to see if theres a fault on the 4x4 screen
Get the 4x4 info screen up and select chassis view ; the one that shows the four wheels. If there is height sensor fault the bar over the offending corner is in red instead of white I think (never seen it on mine so not 100!). |
Have you had a full 4 wheel alignment after having the wishbone changed? |
i actually took it into have 4 wheel and they said they couldnt do it properly because it was sagging on that corner obviously it effects the camber and everything .
