Home > Technical > New Battery
g8lmh
New Battery
Hey Guys.
Quick question.
Can I replace the battery on a 2006 without needing the dealer?
Will removing the battery cause any issues? Do I need a factory reset? Audio codes? Security codes?
Cheers.
Lee.
Post #442104 Mon Nov 10 2014 2:15pm
Bodsy
Site Sponsor
Yes you can , no problem.
You need to reset the clock... Whistle Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #442108 Mon Nov 10 2014 3:20pm
g8lmh
Much appreciated. Friday's little job. Ta.
Less apprehensive now.
Post #442115 Mon Nov 10 2014 4:27pm
Wayneclarke
Just changed mine the weekend only a 15 min job Thumbs Up
Post #442119 Mon Nov 10 2014 5:29pm
SRE
Spain
[quote="Bodsy"]Yes you can , no problem.
Book an osteopath first Rolling with laughter In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #442120 Mon Nov 10 2014 5:31pm
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
As per the LR sticker beside the battery, let the computer turn off first!
Regards
Barry 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #442127 Mon Nov 10 2014 7:17pm
g8lmh
Thank you kindly guys.
How long before the computer switches off?
Should I leave the battery disconnected for 15-30 before recinnecting new one?
Today is the day. Hope everything returns as per normal.
Lee
Post #442538 Fri Nov 14 2014 7:12am
Barryp
Its on the sticker beside the battery, from memory its only a couple of minutes. Once main display goes of computer is shut down.
Regards
Barryp 2017 Range Rover Sport TDV6 L494 SE Fuji White
Post #442541 Fri Nov 14 2014 8:02am
Somerset Bumpkin
2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Reminds me of that scene in Jurassic Park..
Post #442566 Fri Nov 14 2014 2:14pm
SRE
Spain
You could do with the bonnet open fully up against the screen, it's a big old heavy lump. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #442570 Fri Nov 14 2014 2:59pm
Barryp
Replaced in my D3 and RRS with bonnet in normal open position without any issue.
Regards
Post #442606 Fri Nov 14 2014 8:50pm
