Home > In Car Electronics > Rear demister switch off
BRO-T
Hi everyone.
On my previous cars, my rear window demister button once pressed (turned on) would automatically turn itself off again several minutes later. It's varied from 5 to 10 minutes. On my fiancés Clio its about 10minutes.
My RRS doesn't do that and stays on until I manually press the switch. Is this normal? I drive to work which takes about 30minutes and the rear demister can still be on when I arrive.
Post #442092 Mon Nov 10 2014 12:49pm
What model year do you have?
I thought mine turned off after about 15 mins on my MY12, but not sure if that was the case for all models.
Hopefully someone more knowledgeable (not difficult Embarassed ) will be along soon Thumbs Up ON THE WAY: BMW F21 M140i
Post #442094 Mon Nov 10 2014 1:14pm
BRO-T
I have a MY2010
Post #442106 Mon Nov 10 2014 3:22pm
From a MY10 Owners Manual: Thumbs Up
HEATED SCREENS AND MIRRORS
Press button to operate the required screen heater. The screen heater(s) will operate for a
timed period before automatically switching off.
The screen heaters will be automatically switched on if defrost mode is activated or if the external air temperature is low.
Note: The screen heaters only operate when the engine is running.
Doesn't say what that timed period is though Confused ON THE WAY: BMW F21 M140i
Post #442107 Mon Nov 10 2014 3:29pm
