Home > Off Topic > Typical! |
crammy Member Since: 21 Aug 2014 Location: essex Posts: 167 |
God i cant stand boilers. The winter before last our boiler started playing up and wouldn't ignite from the timer. Someone came out to look at it and said it was so old it wasnt worth spending money on it but and lords being tight he fixed it, and then fixed it again and again ect as he refused to pay for a new one. it eventually wouldnt fire up with hot water and had every part replaced nearly and then finally the pcb gave out with a bang ond blew the electrics somehow. this went on for about a year and it had over 800 worth of parts. low and behold he finally fitted a new one. he should of done that when advised and would of saved himself 800 . the original boiler was over 20 years old |
Thu Nov 06 2014 3:16pm |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 |
some boilers blow the pcb board if the fan goes, but you need a new pcb board fitted to get the code
Thu Nov 06 2014 3:32pm |
Another boiler hater here too!
Thu Nov 06 2014 5:18pm |
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 |
We had a similar situation this time last year with the boiler not firing up. I took out a fixed price repair with the manufacturer at £185.
Thu Nov 06 2014 5:25pm |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
RRSTDV8, do you have a hot water cylinder with an immersion heater? You can switch it on to get at least hot water until your boiler is fixed.
Thu Nov 06 2014 7:01pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8931 |
It looks like ours is a fan and/or pcb problem. They're coming back out tomorrow afternoon to have another look at it. Already suggested a new boiler might be cheaper in the long run than trying to sort the no-name thing put in by the previous house owner. Pcb is c.£300 apparently! 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu Nov 06 2014 7:32pm |
Sadly not - it's a combi 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu Nov 06 2014 7:33pm |
I was quoted £300 a pcb though the first time the supplier refunded the costs
Thu Nov 06 2014 8:15pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 934 |
boilers always go wrong in the winter months ..... never in summer. Earlier this year we came back from holiday to find the boiler had :censored, : its pants. Four days before i could get replacement fitted, the Rangie was actually warmer sat in the garage than it was in the house. 2010 RRS, TDV8
Thu Nov 06 2014 8:34pm |
RRS Daz Member Since: 23 Jan 2012 Location: Yorkshire Posts: 797 |
Maybe I can give advice here as I am a gas safe engineer.
Thu Nov 06 2014 9:09pm |
Boilers have become more "complicated" in recent years to be more energy efficient it's as simple as that. |
Thu Nov 06 2014 9:11pm |
What's the make and model? Explosive ignition can be something as simple as the spark gap, cracked burner, spark generator failure more than the wrong gas/air mixture as it's the build up of gas/air inside the heat exchanger before the spark lights it. |
Thu Nov 06 2014 9:15pm |
Sounds like he got into the job too deep before checking the simple things. Before the boiler starts sparking the pcb runs the fan to full speed, make the air pressure switch then the pcb sends power to the gas valve at the same time it sparks. (Whilst also checking the ntc's are in range, running the pump and checking other safety devices) |
Thu Nov 06 2014 9:20pm |
It is the ironically named 'Potterton Suprima 80'. When I've looked up the faults on plumbing forums it seems this model is pretty crap. Any recommendations on who might be able to fix it? Thanks, P. 2008 MY Java Black TDV8 HSE |
Fri Nov 07 2014 11:06am |
