Home > Technical > Heated Seat . Screen Failure - Intermittent - 2009 TDV8 |
lesworth Member Since: 25 Jun 2014 Location: Essex / Suffolk /Cambs border Posts: 16 |
For the last couple of days, the driver heated seat hasn’t worked immediately on start up. You switch it on (lights ok) and doesn’t get hot. After some time into the journey, if you switch it off and then back on it seems to work.
Thu Nov 06 2014 10:15am |
Thanks - that makes sense. Do you know what that hierarchy is? |
Thu Nov 06 2014 11:37am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
As below. When cold, for example, the system will reduce power to the air suspension, then the front seats etc., then inhibit the front seat heaters and so on. Hopefully this makes sense.
A bit more (ECT is engine coolant temperature)(ATC is Automatic Temperature Control module): 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu Nov 06 2014 1:18pm |
Splendid - that is extremely helpful. I'll test the battery and alternator output and see whats what. |
Thu Nov 06 2014 3:03pm |
