Home > In Car Electronics > Newbie Sat Nav / DVD / reverse camera question.
JamesRoberts
United Kingdom 2005 Range Rover Sport TDV6 SE Cairns Blue
Hi Guys,
Probally a stupid question to some of you but having gone through all the posts I'm still not sure of the answers, although I now know what a GVIF is!!
2005 RRS SE. Found the sat Nav under passenger seat.
1) if I buy a cheap upgrade 2012 disc is it just a case of putting the new disc in??
2) I notice the unit says DVD player. If I put a DVD in will it play on the centre screen? And how do I control it and will it have audio. If not, what do I need to do?
3) I have been looking at one of these....
http://m.ebay.co.uk/itm/371177731152?nav=SEARCH
Will this automatically start up when I go into reverse or will I need to activate it each time.
If you know the answer to one or more of these would really appreciate your advice, or any other simple solutions to the above.
James
Post #441641 Wed Nov 05 2014 10:41pm
Bodsy
Site Sponsor
many sources of satnav disk if you search, but LR will still provide the genuine 2011 disk (I think they may have calld it 2011/12) but you won't get newer than that I'm afraid.
When you do source a disk, yes, just eject the old disk and put a new one in (you may need to slide the lock on the other side of the drive in order for it to eject) put new disk in, let it do its update and jobs done.
It won't play dvd's
You need the gvif, if you have that, then reverse camera will be automatically switched (as long as you are on the satnav screen)
No point using those wireless ones on RRS as you won't fit the receiver in the tailgate. You also still need to route the wire to the number plate light anyway for power so a bit pointless on a RRS. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #441643 Wed Nov 05 2014 10:56pm
JamesRoberts
Thanks so much for your quick reply.
I'll order a disc off ebay, look where I'm going in reverse and use iPads !!!
Cheers got your help!
Post #441644 Wed Nov 05 2014 11:01pm
Bodsy
Site Sponsor
If you want any software updates, I'll be down towards Salisbury area in a couple of weeks Thumbs Up Bodsys Brake Bible
See it HERE
Post #441646 Wed Nov 05 2014 11:08pm
JamesRoberts
Great , I'm in the uk till 29th then back out to work for a few weeks. Let me know closer when you will be there.
Post #441650 Thu Nov 06 2014 2:33am
