Home > Faults & Fixes > Battery Drain
Lewis-Oddie
Battery Drain
Morning Folks,
Think I have a battery drain issue. I started to get some starting problems in the morning so decided I needed a new battery. I ordered a new one and shoved that on the car only to find that it still struggled over the next few days. I purchased a multimeter and the battery was only showing 12.2 volts. I checked the original Yuasa battery that I had just removed and that was showing 12.7 volts. So, I put the original Yuasa on a trickle charge for 24 hours and put that one back in the car. Checked it a few days later and it is down to 12.4 volts, 12.1 volts when I turn the ignition on.
Any ideas folks ?
Post #441334 Mon Nov 03 2014 10:20am
Lewis-Oddie
Anyone ?
Post #441537 Wed Nov 05 2014 8:27am
SRE
Spain
Do a search on the sister D3 Forum, loads of info on there about this. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #441540 Wed Nov 05 2014 9:07am
Lewis-Oddie
I've had a look over there but can't find too much to be honest. The only one thing I seem to keep coming back to is the recall from Land Rover due to the instrument cluster not shutting down properly. I've spoken to LR and they say my car isn't affected
Post #441560 Wed Nov 05 2014 11:09am
