Home > Maintenance & Modifications > terraclean |
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 |
How did you find the Terraclean, and how has the car been since? Ive got mine booked in for a remap in the morning and im wondering whether to have the terraclean done at the same time as they also offer that service. 2006 HSE for Sale - £7,499 (Manchester) http://www.rrsport.co.uk/forum/topic46383.html |
Tue Nov 04 2014 8:37pm |
jenko2005 Member Since: 29 Jul 2014 Location: Rhoose Posts: 142 |
my figures have dropped wish i hadnt had it done lol |
Sun Nov 09 2014 11:28pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
I think I read (poss on the Jag Forum) that Terraclean could cause Turbo problems, not sure how, and I am unable to find the original post, but the consenus was that partial softening / removal of carbon had caused a balance issue of the impellor.
Mon Nov 10 2014 9:46am |
From what Ive been told, the carbon build up can "mask" issues that may be lurking in your engine. Once the carbon is removed, then things can arise. I think the main issues can be injectors. There are a few car brands that are more prone to this, but cant remember.
Mon Nov 10 2014 8:00pm |
Darren
Tue Nov 11 2014 1:03pm |
Process:
Tue Nov 11 2014 1:20pm |
I think i will stick to Shell V Power Nitro+ thanks. |
Tue Nov 11 2014 1:28pm |
Well done and dusted.... The car exploded into a ball of fire...
Tue Nov 11 2014 7:43pm |
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 |
What does blanking egr do? 07 TDV8 + BAS map |
Thu Nov 13 2014 9:17am |
So I'm curious now. What is the turbo valve? I can understand that the turbo variable vanes might be full of crud but an hour to get access and clean them? Seems a bit quick for what would normally be a body off job? 2008 MY Java Black TDV8 HSE |
Thu Nov 13 2014 12:15pm |
think I miss-heard him. Not sure what it was, and im not technical so couldnt even hazard a guess. It was a small plastic bleed type thing, sat on the top of the engine, but under some pipes??? As said, im not technical and probably got the wrong description!
Thu Nov 13 2014 6:27pm |
Was it an electrical item, it so could have been your MAP sensor
Fri Nov 14 2014 10:08am |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
hodjie, i'm sure you ment 50MPH not 50mpg itisme |
Fri Nov 14 2014 4:05pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4403 |
My 2.7 has cracked 37mpg |
Fri Nov 14 2014 6:51pm |
