Home > Wheels & Tyres > What tyres are best for 22s?
big pimp
Hi guys.... Been Reading up a fair bit about 22s, and was just wondering what tyre size would be best for giving decent protection?
I know a few are running 265/35 but I'd be under the impression these would be quite 'low-profile'?
Working it out a 265/35 would have 92mm of rubber whereas a 285/35 would have nearly 100mm of rubber to protect the wheels.
So what are the options out there. Is anyone running a bigger profile in 22s (and do they have any pics?)
also, what can be fitted to a MY10 RRS? Is there a limit profile?
Finally, what would be a good tyre for 22s for probably a bit of 'soft roading' as um sure road tyres would end up getting stuck on a beach etc?
Thanks
Post #267610 Wed Jun 02 2010 8:08am
Jonny Fresh
I would say with 22s get as much rubber as possible (without exceeding the maximum overall wheel/tyre size - which im not sure what it is).....
Regarding off roading (even soft) with 22s this would not be recommended.
Post #267623 Wed Jun 02 2010 9:20am
A12DY B
As above I would not recommend 22" for anything but road use and 22" tyres are designed for road only.
I use 285/35/22 Toyo proxes as did I previously, no complaints
I did try a set of cooper avon and they failed under the weight and side walls cracked
hope that helps
Post #267639 Wed Jun 02 2010 10:45am
big pimp
Thanks for that guys... 285/35s it'll be then I guess!
Why would you not recommend 22s on soft (grass, sand etc) surfaces? Is it because the tyres will be road tyres?
Post #267653 Wed Jun 02 2010 12:14pm
big pimp
As opposed to 285/35s my tyre guy has looked into 295/30s.
He says the 295s will have the same rolling diameter as the 285s but are a fair bit cheaper.
Can anyone see any problems with the change from a 285 to a 295?
Thanks in advance
Ross
Post #268122 Tue Jun 08 2010 1:50pm
big pimp
Bump.... Can anyone help or offer advice?
Post #268148 Tue Jun 08 2010 7:13pm
Bladerider
England 2006 Range Rover Sport Supercharged HST Java Black
I use this tyre size calculator...
http://www.tyresave.co.uk/tyresize.html
...which helps me check if I fancy a change of rims or altering sizes for a "stretched" look on certain cars. Generally you dont want to exceed 2% difference to original if you can help it as even at 70mph the speedo would be no more than perhaps 2mph out from what it was. If you consider that a 285/35/22 is the "standard" tyre then you could drop down to a 265/40/22 and have virtually identical rolling radius and be well under 2% out and gain a good few mm in sidewall - 106mm in crude terms as you described earlier, this is more than both the 285 and 295/35/22 options.
Obviously having a slightly larger sidewall size will soften the ride a tad, ease the punishment the wheels have to put up with and perhaps help with tramlining a touch. Downsides to a higher profile, skinnier tyre would be less direct turn in, slightly vague steering, more tyre squeel and less ultimate grip. Personally I think these are all moot points as a 265/40/22 is already such an extreme tyre that you are kinda swimming uphill !!!
Hope that helps.
james. Eat. Sleep. Race. Repeat.
Post #273293 Sat Aug 07 2010 1:49am
jdef90
Poland
this calculator would help you also compare the rims as well as the tyres.
it may be helpfull to estimate the overal "space" which the new wheel will need
http://www.rimsntires.com/rt_specs.jsp
Post #273294 Sat Aug 07 2010 6:52am
Michael7s
England 2010 Range Rover Sport TDV8 HSE Santorini Black
does anyone use 285/40/22 ?
yes, I read about speedo showing different speed, but I'm more interested if they are going to fit arches without rubbing.
They would be 29mm (3,80%) higher than 285/35/22.
Reason for asking is I can have 285/40/22 in quite good price and could do with higher tyres due to comfort and less stress on wheels.
Post #441445 Tue Nov 04 2014 9:14am
Disco
If this is for a RRS2 then 275 40. They are not a road tyres the Std Contis.
Not much else around in that size.
Post #441477 Tue Nov 04 2014 6:17pm
Michael7s
RRS 2007.
275/40/22 are 779mm, and 285/40/22 are 787mm. Just 8mm between them.
I guess it shouldnt be a problem
Post #441487 Tue Nov 04 2014 7:03pm
Olly-ibiza
mine is on toyo's well worth paying extra for tyres, the cheepo budget ones fall apart well before wear is an issue
Post #441513 Tue Nov 04 2014 10:25pm
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
285/35/22 LOOK better but 275/40/22 have less chance of hairli e cracks I have experienced both silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #441515 Tue Nov 04 2014 10:39pm
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
The only tyres that make sense on 22's are 285/35/22 for me. I'd guess lower profiles would compromise the suspension too much. I've already to replace all my bushes. So it's a no go to drop to 295/30/22 for me.
Toyo look great on 22's if that helps.
Post #450521 Sat Jan 31 2015 12:44pm
B9BS X
I've got 295/30/22's continental sports all round, worth paying a little extra compared to the budget tyres Thumbs Up RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #450559 Sat Jan 31 2015 4:55pm
